1987 T type w/astroroof 82k orig
BoostedTtype
Selling my 1987 Buick Regal T type. Car has only 82k original miles. Vehicle is garage kept. I purchased it from the original owner. It also has the factory astroroof and G80 8.5 posi rear. NO rust car is solid. All panels are good. No bondo.. All floors are solid and frame is clean (no rust). Everything works. Ac needs recharged. Heat works great. Transmission shifts great and firm through all gears. Brakes operate 100%. Fuel and brake lines are rust free. Front tire tread is good. Rear tires are Mickey Thompson Drag radials that need to be replaced. Headlights, Taillights, and blinkers all work 100%. Bumpers are solid with no rust.It is cosmetically stock with some tasteful performance modifications. Mods They include
-9/11 Billet converter 3200 L/U
-Cometic Head Gaskets
-kirban 100# springs
-3" terry Houston downpipe
-Scanmaster
-Autometer gauges (boost,oil psi,coolant temp)
-Razors alky control alky kit
-40lb injectors
-Walbro fuel pump with Racetronix hotwire
-Racetronix Dual fan harness
-F Body radiator
-Dual electric fans
-New kirban wires
-ATR stainless catback
-Original 82k mile Astroroof car!!
Quick car with time slips to prove it. All the supporting mods are done. Coolant temp never raises above 175..
Now for the bad
Ta49 has some compressor wheel damage.. It spools nicely but just a fyi
Car runs good (no smoke or missing) but has a noticeable valvetrain noise. Possibly a bad lifter.. Wiped cam etc...I don't believe the bottom end is damaged but I'm not a pro.. Engine would in My opinion need to be gone through before being driven or raced again
Sunroof motor needs to be replaced.
Needs one front bumper filler
Bumper fillers need to be painted.
Located in Southern Md
Asking 7,500 obo
