1987 Stage II White T
mturbo87
Mike
Listing for a friend, please dont ask questions if you have no intrest. Thanks
Stage II off center( New rebuild)
BMS 3.625 in strocker
Carrilla rods
JE pistons
GN-1 heads
T+D 1.62 rockers
Stock intake and front cover
Fluid damper
224 224 weber buillet cam setup
John Craig 76 turbo
Vince Janis Builet 200 r4
Art Carr 9 inch
SFI flywheel
96 lb injectors
3 1/5" THDP
TH custom Headers
Red double pumper
Reds volt booster
Fast XFI
RJC mega cooler
custom 4" inlet
6" K+N filter
H R rear upper and lower control arms
H R 3" drive shaft
H R poly engine mount
Drive shaft loop
Church anti roll bar
8 1/2 rear end with 31 spline Moser and Eaton center
Welded axle tubes with renforcement tubes
Alum core support , alum bumper inters and alum bumper extentions
2 1/2 ATR stainless exaust with dynomax stainlex muffs
Bogart Force 5 rims 4 in front 8 inch rear
Paint is excellent and car has allways been garage stored
A/C and defrost are the only options
Marroon Interior
$30.000 Will get Pics ASAP
Carrilla rods
JE pistons
GN-1 heads
T+D 1.62 rockers
Fluid damper
John Craig 76 turbo
Art Carr 9 inch
SFI flywheel
96 lb injectors
3 1/5" THDP
TH custom Headers
Red double pumper
Reds volt booster
Fast XFI
RJC mega cooler
custom 4" inlet
6" K+N filter
H R 3" drive shaft
Drive shaft loop
Marroon Interior
Where are the pictures?!? 30,000 for a TR? I'd like to see what you think 30grand worth of TR looks like.:wink:
Got a few pictures tonight, as you can see we cant clean up till the weather warms up and salt is of the road.
More pics
Buy it, drive it,and then go buy a 2010 30,000 dollar car and compair them both. Im sure youll understand why its 30.000.......................................
Understood! I just wanted to see it:rolleyes: Nice car, how are the powermaster brakes with that set-up?
Good Deal on a nice Stage car!
Justin, until you try to build a Stage car, you dont have a clue what the costs can add up to. Trust me.:rolleyes:
do you still have the photos of the black t? looks like similar in build and maybe a little better:biggrin: that's what $30 or more looks like.
You stole that care for what your paid!!!:biggrin:
Nice car. Well over $50k to built it im sure. Is there no roll cage or is it just driven on the street with mild strip?
No cage, motor has not been run at track, had a 109 build that ran TSS in Bowling Green. Motor was installed last month with XFI and RJC mega intercooler.
This is a very nice TR. I saw this car up on a lift and the underneath of it is just as clean. Car is from the south so no rust. Good luck with the sale. Someones going to get a good running car!
