1987 Buick Turbo-T
TKMBUICK
1987 Buick Turbo-T
Chrome Package
White with Blue Interior with Bucket Seats & Console
Concert Sound II with Power Antenna
Air Condition
Tilt Steering Wheel
Electric Trunk Release
Delay Wipers
Autometer Ultra-Lite Oil Pressure Gauge
Autometer Ultra-Lite Water Temperature Gauge
Autometer Ultra-Lite Boost/Vac Gauge
Autometer Ultra-Lite Volt Gauge
Knock Gauge
Console Gauge Pod
A-Piller Triple Gauge Pod
Scanmaster 2
Shifter Detent Plate
Simulated Aluminum Speedometer Pandel Kit 145MPH
Turbo-T Black Glovebox Plate
"T"- Black Pullstrap Screw Covers
Houston 3" Down Pipe with Cutout
Houston 2 3/4" Cat Back with Dynoflow Ultra Flows
March Underdrive Pulley Set
Tinman Cold Air Kit
Upgraded Alternator Pulley Fan
Black Powered Coated Mass Airflow Pipe
Black Powered Coated Inlet Pipe
Passenger's Side Breather By-Pass Kit
Custom Made Oil Fill Tube Breather
Drivers Side Relay Cover
RJC Airflow Distribution Power Plate
EGR Block Off Plate
ARP Head Bolts
Brass PVC Shut-off Check Value
5 Angle Value Job
Manley Stainless Valves Both Intake & Exhaust
SBI Push Rods
Teflon Coated Cam Bearings
Comp Cam# 69-248-4
TPS-TEC Throttle Enhancer
Stage II/TA 49 Inlet Bell
Torque Strap
High-Performance Mag Plug Wire Set
Fuel Pressure Test Gauge
Quad Air Fuel Pump
Fuel Pump Hot Wire Kit
ATR Fuel Pressure Regulator
42.5LB Injectors
Cotton's High Voltage Coil Packs
Air Volt Booster
160 Degree Thermostat
Duttweiler Big Neck on Stock Intercooler
Custom Build Trans
2000 Stall Lockup Tonventer
Deep Aluminum Trans Pan
Shift Kit
ARP Torque Converter Bolts
Front Frame Braces
Connecting Front Brace Kit
Under-The-Hood Brace Kit
Rear Seat Frame Brace Kit
B&M Line Lock
3:42 with Auburn Pro Posi Unit
Custom Rear Pinion Snubber
Tubular Upper Control Arms
Billet Aluminum Lower Control Arms
Ebelbrock Tubular Frame Braces
S-10 Rear Wheel Cylinders
Soft Compound Rear Brake Shoes
1 1/2" Front Sway Bar
1 3/8" Rear Sway Bar
KYB Gas-A-Just Shocks
Driveshaft Loop
Airlift Drag Bags
Trick Flow Rear End Cover
GN Rear Spolier
Aluminum Front & Rear Bumper Supports
Quick Grille Emblem
GTA Wheel Capp with "T"
Quick Release License Plate Bracket
Vin# 1G4GJ1170HP426086
AR9 C60 E5Z GU6 NA5 N89 UM6 U75 V73 11Q 27I 7YW
A01 D35 FE3 G87 LC2 NP5 PON UQ1 VD6 YT9 11U 279 8PZ
BS1 D55 FFL J42 MW9 NQ5 QYZ UW4 VD7 Y56 27B 6YX 9PZ
B94 D7I GMD J50 MX0 N33 T47 U23 VK3
U.WA3967
$9800 or best offer call Tim 267-243-4792
email me for pictures
tkm55@verizon.net
Heads ported? Hardtop? Mileage on engine,tranny.body, any pics? If you need for me to post them for you just email them to me. A lot of nice cars down in the pa area lately
