Project update
Ok, over the weekend I was able to make progress on putting this thing together. As I said previously, the idea of doing a replica 86/87 turbo set-up ran into problems due to the overall dimentions of a BBB. Specifically, the turbo height & serp system interfearence
So, I'm switching gears and going back to "just" a 455 Stage 1 set-up. I was able to mount the engine and start doing the hook-ups. I built a non-a/c heater box (using Vega parts) to allow for some heat/defrost features (still appears to be a heater delete car. Still working out the details on that one.
The engine settled down nicely into the mounts, and has plenty of room to run an open element air cleaner. This week I will be back under the car to work on the hook-up and will run the dual exhaust from the GS out to the back. I'm installing a B&M shifter to control the TH400, but the rest of the interior is going to be "stock" turbo coupe issue. Cross member is out of a '67 GS400 and was modded to make the length work. The 68-72 unit is a better fit (fresh out :frown
, so if anyone else is thinking of going this route...
Still going to run a stock 7.5 in the back, but when I sell (or break it), I have a Ford 9" w/28 spline axles to send with it. I'm also updating the steering shaft to a Jeep unit and need to find a set of braided steel front brake lines to finish out the brakes in front.
Oh yeah, I also reinstalled the front clip last nite, glad I had help! :biggrin:
Later,
Jim
