Race Ads | For Sale: 1972 Nova drag radial 9 second street car
Powered by a BBC with....
Merlin steel heads with crane gold rockers and Crane stud girdles.
Manley H beam steel rods
GM steel crank
Gm block
Moroso blueprinted oil pump
Cloyes hex adjust cam chain set
heads and bottom end studded
Aluminium high flow water pump
Sig Erson cam and flat tappet lifters
4150 manifold with 4500 adapter and 1050 three circuit Dominator carb.
NOS Big shot plate with two stages. First stage off timer and 100hp
second stage off button and 150hp
Hooker headers with 3" pipe and splitflow mufflers leading over the axel and out the back
MSD ignition includes...
6 AL box
Billet distributor
3 stage retard box
HVC coil
Superconductor wires
Turbo 400 tranny with Hughes brake
red clutch plates
Coan 4000 stall converter
34 element sprag
JW ultrabell
Hughes SFI flexplate
B&M Pro ratchet shifter
GM 12 bolt with 33 spline moser c-clip eliminated axles
Strange spool
373 street gears
TA performance cover
multileaf springs with slapper bars
car mini tubed to fit 275 drag radial with no clearance problems
The car is a full interior VERY clean no rust Arizona car! The paint is factory butternut with deep blue pearl clear coat.
4 3/4" Harwood cowl hood
New PPG tinted windshield
8 point roll cage
Cloth covered racing buckets
new SS style door panels
new headliner
factory backseat
Full stereo system
Billet specialities street lite wheels
MT 8 ply front tires
Nitto 275 extreme drag radials on back
Car has ran a best of 9.60 @ 138 on a basic pump gas type tune up. 60' in the 1.30 range leaving off the tranny brake at 3800rpm.
This is a very streetable car and a sleeper. No disappointments.
$18,000.00
GM steel crank
Gm block
6 AL box
Billet distributor
3 stage retard box
HVC coil
red clutch plates
34 element sprag
JW ultrabell
Strange spool
373 street gears
8 point roll cage
new headliner
factory backseat
Full stereo system
$18,000.00
