1965 Cobra 427 S/C Roadster Replica
GN Junky
Yellow w/ Black Stripes. FFR Mark II Roadster (FFR3923K) for sale. Car was on the road May of 2003. Since built I have put just over 7,000 miles on it with no problems.
I live about 40 miles west of Cleveland, Ohio.
Car was built me myself, a diesel mechanic/welder with over 22 years experience.
Engine details:
Engine had been rebuilt. 7,000 miles on rebuild. It had 93,573
miles on it when rebuilt.
5.0L EFI
Explorer upper intake
GT40 lower intake
Intake heat spacer
Holly adjustable fuel pressure regulator
Stock heads (ported, 3 angle valve grind and FMS 1.6 aluminum roller rockers)
Double rolller timing chain and gears
Under drive pulleys
New alternator
New water pump
New starter
New oxygen sensors
New spark plugs
New spark plug wires 8mm
New distributor cap and rotor
New clutch, pressure plate, throwout bearing and pilot bearing
Moroso radiator T-fill
FMS stainless ceramic coated 1 5/8 in. headers
Ceramic coated FFR side pipes
Energy Suspension polyurethane engine and trans mounts
Electric cooling fan sender, comes on automaticlly and also have
manual switch on dash
New radiator
Transmission:
5 Speed with Steeda Tri-axe shifter.
Trans was taken apart and new input shaft,
bearing, syncros and seals replaced.
New u-joints on drive shaft.
Suspension and Brakes:
8.8 Mustang rear end with 3.55 gear
FFR rear upper and lower tubular control arms
New rear shocks
Brake parts are all new
New e-brake cables from e-handle to drums
New US Wheels series 94 wheels with center caps, June 2004
New GF Goodrich Radial T/A's, 235/60-15 Front, 275/50-15 Rear
June 2004
FFR front fully adjustable upper control arms with Pro Shock coil-
overs
Mustang lower control arms with new bushings and ball joints
New manual steering rack
Aluminum offset steering rack bushings
New steering shaft u-joint (replaces stock rag joint)
Power brakes (95 Villager master cylinder with remote reservoir)
MISC:
Tonneau cover, custom made to fit over Street Performer Seats
Car cover with storage bag
Insulation under carpet
Russ Thompson throttle pedal, brake and clutch pedal pads
Master cut off switch with jump studs in trunk
New fuel tank and fuel sender
Ceramic coated side pipes
Heater
Fresh air vents
Tri-axe shifter
Alumiunm / rubber roll bar bezels
Fuel cap that you don't have to remove to fuel up
Aluminum windshield mirror mount with Raydot mirror
Street Perfromer Seats with Breeze seat mounting brackets
Windwings and sun visors
Cigarette lighter plug-in
Fuel/air mixture gauge
Pro shift light (can set RPM that light comes on)
Paint
Candy Yellow with Black stripes (Base coat was white mixed with
clear - 4 coats, Color coat was candy yellow mixed with clear - 4
coats, stripes have 3 coats of black. Covered with 3 coats of
clear )
Go to this link to see pictures of the car. http://community.webshots.com/album/131335670MtSiDM
Will include a CD with pictures of complete build
Will e-mail pictures if interested. Will e-mail my phone # if you want to talk!
If you have any questions, just ask!
Asking $28,000 OBO.
Thanks, Jim
