16 pos Max Effort chip for 55`s/ 3 ported TB`s
brian
Senior Member
The 3 throttle bodies are from Steve Monroe. 1 is a 62mm that has been install and lightly used. The other 2 are fresh. They are 62mm and are opened up to 65mm in the rear to be like the old Hemco tb`s. This is supposed to create a "venturi like effect" behind the tb. This is for the lack of a better expanation.:redface: No cores needed in return.
The 62 mm will be $120 shipped. Very nice used condition.
The -2- pieces, 62mm with the 65mm openings in the rear are $145 shipped. These are fresh and unused.
The 3 of them as a package for $360 shipped.:smile:
The 16 position Max effort is for 55lb Siemans injectors. I have all the original instuctions for set up and use. $150 shipped.
Paypal accepted and prefered.
Thanks, Brian
do the throttle bodies fit the stock doghouse? or do i have to open that up to match?
thanks
Jeremy
This post is a year old, but do you still have any of the Steve Monroe TBs?
brian
Senior Member
Send Message User Lists User Notes (0)Edit User Profile
Last Activity: November 15th, 2010 02:15 PM
