H h300r Member Joined May 18, 2011 Sep 17, 2011 #1 will a 275 50 15 mt dr fit with no rubbing will i need a spacer etc i am clueless i have these rims and if they can work on the car would love to use them.thx for any help car has all stock suspension
Q QUIP'6' Brian Roman Joined Nov 26, 2003 Sep 18, 2011 #3 weld doesnt make a 9 inch with 3 inch backspace. its probably a 15x8 3.5 backspace. if so they will fit
H h300r Member Joined May 18, 2011 Sep 18, 2011 #4 ok thx will i have to do any cutting to the inner lip
S Slow91z Turbobuick.com Helper Staff member Joined Aug 7, 2003 Sep 18, 2011 #5 Definitely no spacer needed with that wheel (if it's a 8 with 3.5 bs) but depending on how low your car sits you may have to roll or cut the "lip".
C charlief1 RIP Charlie! Joined Sep 20, 2007 Sep 18, 2011 #6 Slow91z said: Definitely no spacer needed with that wheel (if it's a 8 with 3.5 bs) but depending on how low your car sits you may have to roll or cut the "lip". Click to expand... Unless you convert to rear discs it will fit. I converted to rear discs and the Vectors I have won't work now.:frown:
Q QUIP'6' Brian Roman Joined Nov 26, 2003 Sep 18, 2011 #7 i have that size with them and i have plenty of room. i do have air bags though
H h300r Member Joined May 18, 2011 Sep 18, 2011 #8 i measured again they are 8 inch so i am glad they will fit thx again for everyones help
