RED LS1
SENIOR MEMBER
-Full set of Weld RTS wheels. Great set of wheels for the track. They have some fading to the black but still look good and polish up well. Mickey Thompson street Radial tires in good condition front and back. 275-50-15. Plenty of life for the track. The best measurement I can get from the rear wheels is 15x9 with 4.5” backspacing. Weld uses funny measurements so they are probably their 9.330 they advertise not sure. I had them on a Buick GN and had to use a small spacer. A 1/8 would be perfect.
-3.8 (109) engine Long Block. Stock crank, rods and Pistons freshen up with new King bearings in 2012. Although this ran good in my car with no issues I’m advertising it as “should be freshened up again.” It’s a used engine and I don’t want to sell anyone a problem motor. Compression was around 115-125 across the board. Rare Bowling green customs deep pan, comp 212 flat/T cam, Comp double roller timing set, ARP main studs and head studs. Cometic gaskets, King bearings. Complete OEM heads that are suppose to have light port cleanup and Good valve springs. H&R mounts are not included. $1800 picked up.
-Factory headers and crossover ( drivers sided welded) 175
-Upper water pump pulley 30
-Lower crank pulley 75
-Balancer 80
-AC Y bracket 30
-coolant tube for intake 60
-Coil pack bracket (both pieces) 50
- 60lb injectors I bought new from TT in 2012 and Chip I bought from TT in 2017 that matches. $100.
-Balancer 80
-AC Y bracket 30
