10.23@133mph on pump gas, no alky @ 21psi (total street trim)
ttypewhite
A local and board member "Bird" drove his car to the track (1.5 hours drive) with his kids and ran his full weight T-bar GN with working AC, on 94 octane Sunoco pump gas (no alky, no slicks) He ran 21psi and ran 10.23@133mph, then bolted back in the baby seats and drove back home. Car was driven the same way he came off the street. Congrats again Rich. 109 block with a 70GTQ turbo and the bolt ons
Grand National runs low 10's on pump gas- Video
Thats pretty good for pump gas and a paper clip :biggrin:
No special Voodoo there just a great running combo :)
Tell us more about the car.. I'm very interested in building my WE4 to do this.
This is the Voodoo Recipie he posted for us Locals...
I also found it funny, this is on ET STREETS, Not the drag radials, but the Old schools ET Streets...
This boy can Drive too... No question...
Heres my basic combo,
109 block, 2 ctr steel caps, .030 over wisecos w/mollys
stock standard crank, rods, flexplate, and balancer w/arp bolts
ported, gn1's w/1.55 t&d's, gm steel shim head gaskets.
210/210 .475 .475 cc hyd rlr
pte front mount
70 gtq .85 4 bolt on ctr
atr headers, 3" dual exh(always run closed), 3"dp, and gate w/rjc valve and cheap manual bleeder, 2nd lee gate on the crossover too keep the boost down on the street.
stock ported intake w/1"spacer, kenne bell 70mm t.b. and plenum
200r4 century trans with t-brake and all the goodies.
9" a/c non l/u aprox 34-3600 stall
3.42 stock diff except for mooser 28spline axles.
stock suspension except h&r bar, ss lowers, 90/10 up front, 2 airbags.
stock driveshaft with spicer joints.
home made double pumper stock fuel lines, 75lb inj.
old fast b2b
That pretty well sums it up.
Thanks for posting Mike. As sick as it may sound i was running a little rich with a low 11 afr(watch the black smoke on the video)and i think i can squeak another 1lb or 2 of boost. This wagon might have a 9.999999 on a slick:eek: These cars are way cool. The tsm guys running bottom 9's would be able to put down some solid 9 sec et's on pump gas. Maybe it's time for a new "pump gas class":biggrin: :cool:
