USMC_Turbo6
- Dec 13, 2009
Which is the better turbo the precision DBB 6265S or the turbonetics CPT 66 BB with a P-trim wheel? An why is one better than the other?
tnetics also has billet wheels,a full 1 year warranty,and seem to be less coin.the 62/65 has a smaller comp wheel than the tnetics 66,but both are relatively the same on the turbine(65 is replacement for the ptrim wheel).
I agree.
I recently purchased the T-66 Ball Bearing unit with the .63 Tnetics exhaust housing, similar to the Garret .63
Tnetics balances the assembled cartridge at high speed in a computerized VSR (Vibration Sorting Rig) machine. Add in a built in oil filter, big shaft, polished cover, no need for coolant lines and a full 1 year warranty.
The resale on these turbo's are questionable however. With all this being said, whatever you get a better deal on is what I would go with.
Joe
I have never heard of a Precision Turbo being out of balance and am sure they have state of the art balancing equipment.
Also the new Precision Ball Bearing turbos no longer require coolant lines and are dual ball bearing compared to the T netics single ball bearing.
Also, if you look at the buick oiling system all oil going into your turbo is filtered. the T netics do install a screen in their inlet fitting.
A filter is really only required if your motor is coming apart,there should be nothing in you oiling system that can hurt a turbo.
OK so PTE makes a DBB 66 what is the cost of it. I'm looking to step down in turbo size from my t70bb. An have a buget of about 1500 after I sell a few parts on here. So can tell me who to call and is that a good size to step down to. look for mid 10's and a good acting turbo on the street I have a few car i need to kill
Actually, the new turbo that Harry spoke of yesterday at Caspers's open house, was the new 6466 turbo that is coming out. It features a 64mm compressor wheel and a newly designed 66mm turbine wheel. This turbo will fall between the current 6265 and the 6765 unit. No horsepower figures / results have been posted yet and pricing has yet to be determined. As mentioned yesterday, this unit is scheduled for release in the May / June time frame. I will make sure to post more info about it, once it becomes available.
Patrick
I was ready to run hte balls off your 6262 the other day but did not have enough fuel i the car to push it past 22#s, though we made 545 RWHP at 22#s with it
As of now, I do have the new 2011 Precision Turbo catalog that I can send out to anyone in a PDF format. Just send me an email and I'll email it over. Also, I will be sure to pass along all the updates about our newest turbos, just as soon as they are released. As always, we greatly appreciate your continued support and your business.
Patrick
