Hi guys new to the forum and turbo regal scene. I wanted some of you more experienced guys advice. I bought my 85GN bout a year ago, at that time bone stock. After reading the forums and doing alot of the upgrades you guys were doing to the hot airs (walbro 340 pump, hot wire, adj fpr, 87 ECM, MAF, TT chip, TA33 turbo, adj wastegate actuator, 160 T-stat) I see alot of guys running 36 or 42.5lb injectors but Eric tells me the hot airs dont really need it. Are my stockers not enough for my setup?, not having knock or lean isues just curious. Also the wastegate actuator is universal 7.5psi from horsepowerfreaks. Is that enough?
