Does anyone know if a IAC for a 86/87 will work on a hot air. Reason i ask is I replaced the old one cause it was stuck (constant reading of 90, block INT would not drop below 140) After new one was installed car ran perfect, reading bout 20 at idle on IAC and 128 on INT. After five min of running car died. Resarts but wont idle IAC stuck on 0, even when kept running. Removed new IACand found plunger came all the way out. Both sol's look same far as apperance and length
85Gn astrroof, Ta33c, adj wastegate, adj fpr, walbro 340, hotwire, 87ECM/MAF TT chip, 160 t-stat, blocked tb lines, gutted exhaust
