Motor
Long time No hear LOU thanks for the great job on my motor even it was a baskit case when you got it looking to get some alky work done
turbolou said:Gary does that inter cooler honestly really work any better than the stock one with a bigger neck. My guess is that it doesn't. it would be interesting to test the difference by measuring pressure drop & temp difference across the core which I feel isn't as efficient as the stock design. it was established early on that the stock core worked well the inlet being the biggest draw back.Its just that they tried to squeeze too many rows in such a tight space.
In turn causing a restriction & pressure drop causing the turbo to work harder creating more heat. I may be off base here & really hard to know without some back up testing. So this is only an assumption based on past experience. Lou
