Otto, yes the 88, would eliminate the need for nitrous, but lets look at how many buicks are honestly running mid to low 8's with an 88. We have seen a few, but most are back halved cars, running much bigger tires and lets be honest, pushing way more then 26-30#'s boost, more like 37-42#'s, which means lots of rebuild cost. Fiscus is the only guy right now that I know with a stock styl susp, running faster then 8.50's most of the time. The Reason a few of us crazy guys run something different and bigger, is to NOT have to push our cars that Hard to hit a number. Should we ever want to go faster, then we have the heads and the turbo already to go for a later build. :smile:
Not so sure about that. I believe Ted A is running those times with out maxing his out yet. As far as a bigger turbo and not pushing it, I believe in the end whether its a larger turbo running 25 psi or smaller turbo running 30 psi to run the same ET and MPH its all very similar. As long as intake temps are reasonable the cylinder presure to run those times should be similar from either turbo.
