The Signal Switch Should Be The Same As Many Other G Bodys And Other Gm Cars,should Be An Easy Find At Local Bone Yard. By The Way, What Is Wrong With The Switch?? Signal Not Returning On A Turn??? That Is An Easy Fix.. A Small Spring(clip) Good Luck..
actually it returns after a turn fine, its when the lever is pulled, both sides flash....but when i put some pressure either up or down, it sometimes works. I checked all the bulbs and they seem fine.
