figured i offer it here first, im not totally done taking it out of the car yet but nearly and wanted to gauge any intereset in the unit locally. it will come with the pro unit itself, boost control solenoid, 2 extender chips for 60lb/hr mototron injs, and a untouched splice in harness for the system. unit works fine just has a surface blemish on the front screens plastic does not affect function. all you would need is a 3 bar map, splice in harness for boost control(might be able to get mine out still need to look how i wired it up) and move the iat to the up pipe. and a wideband if you wanted to have a/f correction. i will try and get pics up later $450 for everything
