W Wht87T All Throttle... No Bottle Joined Jul 9, 2001 Jun 25, 2002 #1 The car has an Art Carr shift kit in it. I've been having problems shifting at WOT. I backed out two clicks on the TV cable, still same problem. I'm lost.
M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Jun 25, 2002 #2 Did the problem start just after installing the kit? Has anything else been changed; ie. tire height, gear, etc.?
W Wht87T All Throttle... No Bottle Joined Jul 9, 2001 Jun 26, 2002 #3 The shift kit went in when the tranny was rebuilt. I was running Nitto's (275-50-15's) a hair shorter than 26"
M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Jun 26, 2002 #4 Are you 100% positive that you got your original transmission back from the rebuilder along with the correct valve body & governor?
W Wht87T All Throttle... No Bottle Joined Jul 9, 2001 Jun 26, 2002 #5 100% All components used during the rebuild came from Art Carr (CA.)
M MeanBuicks Scaring the neighbors! Joined May 24, 2001 Jun 26, 2002 #6 Have you posed your question directly to someone at Art Carr?
