C casper Member Joined Jan 3, 2007 Mar 24, 2015 #1 I have a 2006 chevy duramax battery light stays on when truck is turned off and one other dash light. dealership tells me the wiring harness under the dash is bad and the one that goes to the trans. Any body ever have this happen.
garyk1970 Electronics Moderator Staff member Joined Nov 4, 2005 Mar 24, 2015 #2 I've seen a defective ignition switch (electrical section) cause this issue before...very simple to fix
D DarthBuick I Win even in your dreams. Joined Dec 22, 2014 Mar 27, 2015 #3 Check for water or moisture in the transmission module connector. I have seen that happen more than once. On mine the PRND321 indicator stayed on too.
S Steve V Steve V's Automotive 757 560 2782 Joined Jan 5, 2004 Mar 28, 2015 #5 garyk1970 said: I've seen a defective ignition switch (electrical section) cause this issue before...very simple to fix Click to expand... Me too and one that has been installed 1 tooth off can do this as well.
A achalmersman Well-Known Member Joined May 28, 2012 Mar 28, 2015 #6 I just glanced at identifix. For giggles unplug the wiper motor and see if your problem goes away
A achalmersman Well-Known Member Joined May 28, 2012 Mar 28, 2015 #7 Also, do you have a scan tool that will read BCM codes and monitor BCM data stream?
D DarthBuick I Win even in your dreams. Joined Dec 22, 2014 Mar 28, 2015 #8 If you was close I have a tech-2
garyk1970 Electronics Moderator Staff member Joined Nov 4, 2005 Apr 1, 2015 #9 Steve V said: Me too and one that has been installed 1 tooth off can do this as well. Click to expand... Yes there's some timing involved in the installation... I've done that myself....lol
