Wilwood calipers SOLD
PSID6
Set of Wilwood D154 stock replacement calipers with braided stainless lines with adapters for stock brake lines.
Roughly 1,800 miles. $275 shipped
Do they come with pads and can they be used with stock rotors?
Yes I have pads, same mileage plenty of life left in them. Yes they do fit the stock rotor’s and another plus they are almost 10lbs lighter then the stock calipers.
How did you like them compared to stock?
Why selling?
They are marginally better than stock at stopping. I did it more so for the weight savings 10 lbs less than stock pair. Honestly the stainless brake lines are the biggest improvement over the pathetic stock brake lines.
Only reason I’m selling is I bought an entire wilwoood front brake kit and took an additional 30 pounds off the car.
Do the ones you are selling fit GN wheels?
Which kit did you buy? 30 lbs is a nice reduction
I am not 100 percent sure cause I run skinnies but wilwood sells them as a stock replacement so I would think they would.
Honestly I don’t remember the part # of my current kit but all I can remember is that it has a vented rotor for street driving.
If anyone needs a bit more info on these calipers see above
