Will these log style headers fit LT1's
BandAid
Keyboard Bully
I bought these from a guy on TurboMustangs.com almost a yr ago,just wondering if they will fit on the LT1 block,they were made for a SBC motor,thanks for any input
should, a lt1 is still basically a gen 1 design small block, pretty shure the bolt pattern on the heads is the same.
Gary
I think the bolt pattern will be the same, as far as fit, looks like they were installed in a Malibu. If your installing in a G body I don't think your going to have a problem except you may have a problem with the downpipe if you have A/C.as the the Malibu looks as it only has a heater.
Hope it helps, Rink.
Exhaust port shape on the head is different on a LT1 versus ad regular SBC. Should bolt up and work but take a look at this first.
the exhaust ports are D shaped, nothing a little weld and grinding inside the primaries wont cure........
Not sure if they ever made a round exhaust port head in the genII heads...
