No, I called to ask him if he had come across lines that would work for me if the right ones weren't available. His response was as I posted, lines should be matched to the original lines so to have the right bends.
Call me a stickler for details. No it isn't a concourse car but it is mine and I don't like hacks. I see no reason for me to either spend my time doing it or paying someone else to if things can't be done properly. Which in my mind means the way it left the factory.
That said, in the early '90's when I brought the car I took it to a repair shop in the town I was going to school at the time for some minor transmission work. He cut the original lines not too far back from the Radiator and ran copper back to the transmission.
Now I'm doing the front suspension, this time the upper control arms and after doing the DS and ready to do the PS and guess what, I have a damn copper cooling line were it's not supposed to be. It's almost right up against the frame bolts for the pivot shaft making getting a wrench on the nuts almost impossible, turning the nut once said wrench is on there is going to be yet another matter.
That was back in '95 or '96 when had he bothered to even call me I could've gotten new lines from GM.
No Sir, I replaced all my Brake Lines last summer with Stainless Steel Pre-Bent from ClassicTube and will replace the fuel lines the same way.
There's more than one way to skin a cat and this here cat is going to get skinned.
