Greetings all,
Last week on the way home the GN start throwing a code 41 (Cam sensor) and when I shut it off . It would not start again.
Well, replaced the cam sensor , ECU, Ignition module .
I do have 12 volts to the crank and cam sensors and I do have a signal out from both , But I have no tach signal and the coil is not firing (all this measured at the Ignition module with a DVM). Also have power to the ignition module. Unless the ignition module I got was bad, It was used.
Any input welcome and thank you
