G gsx7707 Member Joined Oct 5, 2009 Oct 16, 2011 #1 Recently replaced my tired stock trans with a built 200r4 9/11 converter had no problems with lock up before swap.Im just wondering if it will hurt to drive it until i figure out the problem?any suggestions?thank you
Pronto Believe nothing you hear and half of what you see. Joined Dec 9, 2002 Oct 16, 2011 #2 Was the 200r built as a non-lock?
T TURBOPOWERED68 David Joined Jan 31, 2006 Oct 16, 2011 #3 i read some where ?? that the trans may create excessive heat while cruising at high speeds. ???
T turbofrank Well-Known Member Joined Nov 4, 2002 Oct 16, 2011 #4 Pronto said: Was the 200r built as a non-lock? Click to expand... Are you running a trans cooler ? If not do so and its ok to run for awhile.
G gsx7707 Member Joined Oct 5, 2009 Oct 16, 2011 #5 Pronto said: Was the 200r built as a non-lock? Click to expand... built to lockup
G gsx7707 Member Joined Oct 5, 2009 Oct 16, 2011 #6 turbofrank said: Are you running a trans cooler ? If not do so and its ok to run for awhile. Click to expand... Im running it through the radiator but i have a cooler that i am going to install.what about long term if it wont ever lock?
T turbofrank Well-Known Member Joined Nov 4, 2002 Oct 16, 2011 #7 I ran mine for about 6 mo without lockup gas milage suffered a little. Mentally missed lockup just a smoother rideand less noise.
D dpasadena Member Joined May 18, 2009 Oct 17, 2011 #8 Fluid temps will be high at highway speeds. I would get it locking asap.
S SSedan64 JoaTMoN Joined Dec 8, 2007 Oct 18, 2011 #9 X2^^^, overheat in 4th/OD. The new Tran's internal wiring may be different from your old Trans.
