Will bad 0 ring on input shaft not allow converter to lock?
turbo1962
345
4
18
57
Platte City MO.
I bought a PTS 9/11 years ago from a member less than 500miles after i installed it i never could get it to lock. so i drove it a few years like that. Later on when i removed it i noticed the 0 ring had a little shaved of piece .I figured when i installed the convertor it must of damaged the 0 ring. Would that cause it not to lock? thanks
pacecarta
MAGNA
Staff member
Aug 1, 2003
9,068
747
113
RIP racewaypark, NJ
for lockup you dont need the check valve in tip but you do need the oring on the tip , but if it leaks it will cause it to engage so you need to look elsewhere for the no lock issue, try a new locukup solenoid , check the fuse or brake switch
turbo1962
345
4
18
57
Platte City MO.
The transmission was working fine lock up was working also. All i did was swap the convertor. So i guess the lock up in the work convertor is bad. I was hoping a bad 0 ring would keep it from locking.
Top Bottom
