I don't know of any low maintenance race cars anyway :biggrin:
Stock cam sensors have bushings that can wear and a drive gear as well so what's the difference there?
I dont know of any low maintenance BUICKS!!! :tongue:
you need to use whats best for your application. the DIS in some cases is not enough spark.
Don, the MSD crank trigger wheel (flying magnet) is attached to the crank direct. No timing chain will effect this. The cam sync only give the ecu a reference to the firing order so it can sync the injectors and individual timing. The rotor phase may be a little off because of timing chain flex, but the accuracy of the spark will not be effected.
If you don't have any distributor stuff, I would run the COP setup with a 24x wheel not the 3 pulse/revolution setup.
