I am posting this as an informative post and also a question/open for debate.
In what I have experienced, read, researched, etc.. The reason propane injection has as much effect as it does on our turbocharged gasoline engines as it does is due to 2 reasons.
1) An octane ratine of 108-112 (seen different ratings posted all over the internet)
2) The fact it is a gas and not a liquid.
I believe that the 2 combined also play a mojor role in the combustion process. Since propane is a high octane gas completely mixed with the air in the cylinder, any lean spots will effectively have a higher octane than rich spots. The definition of octane is essentially "the resistance to detonation" and a lean mixture will detonate easier than a rich mixture so therefore if the lean spots have a higher average octane than the rich spots you will be less prone to detonation and also able to make more power than by simply running straight high octane gasoline. Basically since you are injecting about 90% gasoline (91-94 octane) and 10% propane (108-112 octane) you really only have a true octane rating of 92.7-95.8, but actual results show more around 105-110 octane performance.
If anybody disagrees with this or has anything to add to it, feel free as I would like to learn as much as possible about the subject.
