I am looking for suggestions on why the TV cable on my TR is only allowing the throttle valve to open ~70% of the way.
Likewise, my TPS sensor only provides a maximum of ~3.5v (this was the tip off that something was wrong at the throttle valve). When I disconnect the TV cable, the throttle valve will achieve it's full stroke along with 4.8v from the TPS. I believe the transmission was rebuilt or at least a shift kit was installed by a previous owner. The throttle lever is not bent, or damaged and the cable connection is at the correct spot on the throttle valve. I have performed the TV cable adjustment procedure provided in the service manual and it only yields that 70% max. throttle opening.
After reading the TV MADE EZ article, I took a look at the transmission end of the cable. I will use the names referenced by the article to try and describe what I see. When the throttle valve is opened, the TV plunger is pushed into the bushing until it is flush with the end of it. A curled tab on the TV lever assembly (that pushes on the plunger) stops it on the end of the bushing. Also, I can not manually push the plunger in any more from the edge of the bushing.
The TV bushing sticks out about .090" from the edge if the valve body casting. I was not able to get a measurement to the counter bore depth. Is this correct or is the bushing not supposed to stick past the edge of the casting?
The TV lever doesn't appear to be bent in any way. IMO, the parts inside the transmission look like the original parts (this is the only THM200 trans. I have to reference), but will not allow the throttle to open all the way.
Does anybody have any comments or suggestions of what may be wrong here?
Thanks,
Don
Thanks,
Don
