Who makes the best turbo cam for the LS motors?
GNXkid
BOOST
Who makes the best turbo camshaft for the LS motors that you can buy now, instead of having one custom made. Thanks.
It depends on what you want to do.
What turbos, intake, head, rpm etc.
For stock motors and low rpm the late LS6 cam is popular.
GNXkid said:
Who makes the best turbo camshaft for the LS motors that you can buy now, instead of having one custom made....
It's worth it just to have one customized. As for who, Bret Bauer, hands down, just have him spec one out for you....
I take that back speed inc. has the best proven turbo cams TU1 is 225 225 a little under 600 lift 114 LSA If you don't have a trans brake stick to the smaller cams theres a 4x4 GMC
4800lbs that runs 9.40's with a stock truck intake and a little isky 215* cam shifting at 6200 rpm-88 turbo 370ci.
I'm going with a fairly small turbo and 370 or fewer ci, so I'm going to probably go with a z06 cam.
