where to mount scanmaster
Mine is under the dash pad in the center...wire runs across the seam between the dash pad and the gauge panel to the left side and then behind the dash. I used industial velcro and seem to be holding just fine.
Here's photos from when I installed mine. Permanent install as you can see :) Works for me Scanmaster Install
Only thing is that it slightly covers up the turn signal lights in the dash ... but depends on your height and seat angle etc as well. Not a problem just thought I'll mention it.
I have mine to right under the gauges ... a lil hiden out of plane sight .. stealth mode lol
Mine is in the same place as Jan's too...used to have it to the right of the steering wheel under the dash, could see it through the wheel. It worked well there but like it much better up top in the center...not very stealth though, but the gauge pod and drag radials kinda did away with that anyway :cool:
