Rear end "ring and bearing kit"? Usually a ring and pinion are sold as a pair.
As long as you get good pieces from a reputable company that will hold up to the power, buying local should not be a problem.
There are several shops in the area that do good rear end work if you need it to be set up and shimmed correctly.
