The problem is that the stock fan cannot pull air thru a fm that covers the radiator, the ac condensor, and the radiator. The tranny cooler is just incidental.
My car ran 165 degs at 70 mph on a 103 deg day so there was obviously nothing wrong with the basic cooling system other than cool air was not getting to the radiator when parked in a line of traffic.
If 20% of the core had been exposed to direct air flow, I would have had no problems.
Yes, the baffling was retained so that all air that could, did go thru the radiator.
My car might run a bit hotter being bored plus 30, running 9-1 compression, and using R134A freon. I suspect only the latter has any real effect on the temperature. I also know that running the tranny cooler thru the radiator added about 10 degs to the idle temperature.
I never got over 193 this summer so I know that I finally got up to the problem.
I don't feel too bad because the majority of people running V2s or PTE ics have the same problems as I do when they live in similar climates.
Be that as it may, it has been demonstrated by a number of people that there is basically no difference in performance between a front mount and a V4 until way into the tens for most of us. I have also learned that many don't care about facts and they will continue to believe they will make big gains with a fm no matter what the penalties.
