wheels ordered, what tires and size?
maxcom
Ordered the Classic Industries GTA ALLOY WHEEL SET zero offset
MT 255-50-16 rear ?
brand ? 245/50/16 front ?
and a good place to find centers and lug nuts
thx!
hello people; 16 inch tires are getting limited in choice. If it's not too late go for some 17's. And make it easy on yourself and keep the same size all around. I still have 16's 245-50 all around and the next time I'am going 17 if I can afford it. I have my eye on Vintage Wheel Works 45's or something similar. But that could change.
IBBY
going with the MT 255-50-16 for the rear........... any suggestions for the fronts?
You need to change your signature. Seems some things have changed in your setup to the best of my knowledge. Don't know much about tire sizing. Sorry for the hijack!
225's. 245's on a 87 I had here rubbed a little also. Wasn't bad but they did make contact.
hello people; The 245's do rub a little in the front when you turn the wheel all the way and if your into a turn and hit a large dip. But the tire makes it's own home with the inner fender well and they get along after while.
IBBY
