Is there any difference in pedal feel, effort, or travel when using the S-10 wheel cylinders with the larger bore?
I just did this switch (after rupturing a cylinder on one side somehow). I switched to the larger bore S-10 cylinders, and for some reason I cannot get back the same high pedal that I had before. I'd like to think I still just have air in the system somewhere, and should bleed them a little more. Reason being is that the braking force isnt all that great either. They wont even lock on wet road.
But curiosity led me to ask if the larger cyls make a noticable pedal difference, being that they compress more fluid within a slightly larger volume.
