Using a needle valve as a restriction between the compressor and the waste gate?
OR
Using a needle valve as a bleeder between the waste gate and the compressor?
Will either spike or be erratic in some way? I am not worried about spool up, only stable boost. Just trying to figure out who has had good luck with what. I am currently running a RJC valve, stock adjustable waste gate actuator with a TA-49 turbo and a THDP. With the stock turbo the boost was right on the money 22psi through all gears, now with the TA-49 I am struggling to even get a consistent 17-18psi and it gets lower with each gear. It just goes all over the place....
Thanks for any help or ideas
OR
