Virgin 109 block with eagle crank 010, je pistons 020 over, 1-2-3 billet caps, champion iron's with 1007 o'ring gaskets, 70gt q trim turbo, big stuff 3 computer system, 212/212 hydr/roller cam, 700 miles on motor, been running 14-15lbs of boost, and havnt been above that!! i have a casper's audio/visual knock detector that is sensitive,and hasnt gone off till trouble's erupted!!!!! i was on a nice parkway and had the motor up to about 4800 rpm, backed off, cruised then back up,and held it there breifly, and then knock detector went off, i looked at oil press,and down to 20psi and dropping, i immed. shut down and coasted to the side, restarted, and motor and was knocking. I towed back and ripped apart, to find head gaskets like new, pistons looking great,nice movement side to side,(RINGS NOT FROZEN) as well as spark plugs looked great,# 23 autolites, front main spun, and the rest of the mains wiped and about to spin. the 3 billet caps actually pinched!!like the crank was trying to blow out the bottom!! rod bearings were all good!!! i cant understand!!!! i gave motor back to machinist after talking to different members on this board running hard, and would agree there was a machining/clearance problem on the caps!!!! this motor is suppose to handle a lot more than this!!!! the machinist is telling me when fully disassmebled, there was almost no top ring left on all the pistons and i was just pushing too much air(70-TURBO) thru the motor and blew it!!!!
just doesnt make sense!!! GUYS, PLEASE GIVE ME SOME FEEDBACK, PHONE #'S AND ANY INFO!!! NOT ONLY DO I HAVE TO FIGURE OUT WHAT WENT WRONG, BUT I NEED TO GET THIS MOTOR BACK TOGETHER,AND MAKE SURE THIS DONT HAPPEN AGAIN!!!! DONT THINK IM GONNA USE THE SAME GUY,AND NEED TO FIND SOMEONE TO GET ME BACK ON THE ROAD!!!!
PLEASE HELP!!!!!!!!!!!
