Some of you may have followed my engine problems, but to sum it up I have a 20 bolt OP hot air motor with a wiped out cam lobe 2 spun rod bearings and 1 spun main that locked the motor. The block and cranked should be salvagable with some machine work. I've got a complete carb turbo motor riding around in the back of my truck. The C/T motor sat outside for a while, it's pretty ugly but it turns over by hand nicely. I also found a rebuilt 3.8 short block with a 14 bolt pan and TC for a reasonable price. The guy that has the rebuilt motor dosen't know the history off it. I'm working on a tight budget but I want/need to get this car back on the road by the end of the year. I'm not looking to build a 11 sec car, just want a decent running stock car that I don't have to worry to much about blowing up. Which direction would you take? Rebuilding the motor that went out seems like the most costly alternative. I could open up the C/T motor and see what the bottom end looks like, switch it over to my hot air set up and cross my fingers. Or I could get the rebuilt shortblock and put my upper end on it. Thanks in advance.
