i vote 210 also. i love mine.norbs said:I would use a 210/210 from PTE, idles sweet and good power, and not hard on parts!
What springs do you have now? The roller cams use higher spring pressure than flat tappet cams, so if you have springs from a flat tappet cam, the answer would be "yes". If the springs are for a roller, then the answer would be "maybe", depending on which roller the springs were for.If I went with the 206/206 roller, would I have to change the springs on the gn1's?
