What size injectors?
blackgn231
Money pit
I am running 37 pd injectors right now with a TA-49, ported and polished irons, 62 mm throttle body, 206 roller, 3inch down pipe, not sure if these are to small anyone?
Your goals aren't really clear, too small for what? Unless you can see what the duty cycle is you won't know if they're too small.
How much boost?
60's seem to be a good choice. Idle is good almost like stock.
Keep in mind that most single intank fuel pumps can only supply enough fuel for 60lb/hr injectors. So if you don't ever plan on changing to a double fuel pump setup, or external setup, then there's really no reason to buy larger than 60's.
ok thanks
Had a friend here that was running 50's on alky so thought maybe mine were to small .
if those are blue tops they will go mid 11s without issues.what times are you running now.set up correctly look like a 11.40 to 11.60 combo
