Boost solenoid, ECM controlled. How are you controlling boost?
Walter
What would be my options for controlling boost?...that being said I have no idea how I'm controlling boost I got the car 2 weeks ago
Take some pics of the drivers side of the turbo(vacuum line routing ) and the passenger side of the turbo(looking for external WG) and post them up here. You will find out how you are controlling boost.
The line that is plugged with the bolt normally goes to the boost control solenoid up on the valve cover. With that setup the only control is with the adjustment on the waste gate actuator. At least it is not hurting anything connected that way. It will keep the boost down at a low level. I would find out from the previous owner why it is plugged and not connected to the solenoid. Possible bad solenoid? If that line was left open you would have no boost control and your boost would go way too high and damage the motor. What chip is in the CPU?
Looks like the chip is written for 93 octane gas, 50lb injectors, 20 degrees of timing, and 16-17 lbs. of boost. Any markings on top of the chip?
