Wanting to know what the cencious, of what is the correct oil pressure that our cars should be running, reason I am asking is that I have finished rebuilding the motor and broke it in, the oil pressure is high very high with the motor cold it runs about between 60 and 70 at idle and can get up to 90 or better at 2500 rpm when the motor is hot it is 60 to 65, I am running mobil syn 15-50 but on going to use 10-30 syn in hopes to bring the pressure down with a lighter weight oil, the front cover has been sent off to TA performance and was blueprinted and the motor was put together with very tight clearances. What are some of the groups thoughts. Jr.
