think about it guys
Think......public forums are great but lets assume the thirves are here.........they are........it would even be possible for them to see where your located and even find your car.........
Lets face it.....there isn t big money in stealing these cars.....they only cost 10k thats nothing in todays car market......they do it cause they know TR's.
Most of the serious guys on this board including myself could steal most of our cars......... I ve had four tr's and two have been attemped.....one was just dumb luck that I got to keep it.....
If you own it they will try, period!
I know to check your fp connector, cam sensor, ecm plug, kill switches , etc.......so do they.
The only thing that keeps your car is time......and risk.
You have to do things to your car that someone else wouldn t do , this could be the ecm wiring speghetti trick......its good......you do it your way........you make your keyed plug.......
I could defeat most of the board members tricks in minutes or less and I ve never stolen a car..........So if I had profound knowledge of over coming alarms and hot wiring(the colum I am more familair with, by no choice of my own) I could get almost any of our cars in just minutes.....not hours.......minutes like under five........
A freinds car was stolen about 2 months ago now......from a big 5 sporting goods, he said he was inside for 4 or 5 minutes tops......and the car was parked with in eye sight of the front door!
You need to buy time......which increases the risk.........the bottom line......the more the better.......
A chip! if you steal tr's chances are that you have a chip to take with you.......lets see, thats 30 maybe 40 seconds to tear the kick panel off and use a nut driver to get the cover off if you put it back on?
Collar gaurds are good.........some better then others.......probably 30 seconds to 30 minutes of buy time there depending on which one and how prepared the thief.
Kill switches.......maybe 5 minutes tops if your clever
Unplugged sensors......1 maybe two minutes.........
Alarm? I dont know.....probably depends on the thief and not the alarm...........3 minutes for a pro to not at all for an ameture.....
ECM wiring plug of speghetti? Virtually impossible to overcome.....the only map is that of the maker.......so short of probing every wire and massive knowledge of specific ecm outputs or imputs........it s not going anywhere other then by tow.......
Brake locks? 30 second s to a minute......easy to cut lines....
Blocking by other cars........great, buys more time before they even get to the big problems.....
Lo jack...???? 600$ thats not even the cost of that front mount.............or that turbo or that.....you get the point......
Might come in handy if they just repo tow it......whats that take....10 maybe 15 seconds tops.......You can watch from 40 ft away and no stop them........repo trucks don t even have to get out of the truck......just back up to it and its gone.......thats gone as in you done.......
Hopefully you will be carrying that ar or 357 or what ever when your eating breakfast with you gf on sunday morning at starbucks........you may need it.....cause you won t be able to get to the car before they leave............physically anyways....
depressing.......Iknow.
