my intake air temp sensor reads about 130-140's at idle when the car is warm, iam sure this is not helping my performance out at all.I have it in a open cone filter in the engine area.
Originally posted by crazygn my intake air temp sensor reads about 130-140's at idle when the car is warm, iam sure this is not helping my performance out at all.I have it in a open cone filter in the engine area.
If you want a real shock mount it in the upper plenum, and see what it does after being in boost for a while.
BTW, there is an unused table in the ecm code that allows for making a timing correction based on IAT. But relocating it fubars the MAF correction.
But, if you use a Translator, the late MAFs do their own temp correction, and don't need the stock IAT/MAF table. So then you can 0 out that correction table, then populate the IAT temp sensor table, and relocate the IAT. So then you have a timing correction for varing MAT/IAT readings.
its going to be hard but maybe i can get it up front some how, will it help a lot, i think it will drop my telps from 130 to about 60-70* at the track.
When I had the K&N in the engine compartment, I saw it flash HOT several times! I relocated the filter down by the air dam and have not seen temps over 110.
i wish i could use that but its in my rx7, i just dont want to get to the track and lose a few tenths in the 1/4 mile over a filter . maybe i wont make that much of a lose but iam not sure.
