What head gaskets are these?
ScottyG
Got a worn out 109 block just using the ported heads off it saw that it was .060 over ? It's like a facotry type gasket but it's 4.010 bore size
looks like a felpro 8723 with some copper paint on it ..its not a turbo gasket ..no bridge on side coolant ports .
060 sounds like a reman for a 3.8L NA
That's a big bore for a 109 block, if that's what it is. But I could be wrong.
Obviously the question is stock or built, but would you turbo said block?
Your experience is far, far, far superior to mine. I recognize that fact, daily. :)
i didnt and wouldnt run a cast on a turbo , someone else tried to use a cheap chainstore reman and met with failure ,,i got to throw all the parts in a dumpster after new owner bought it
Enough said.
OP, you didn't say what heads were on the engine, just "ported".
Is your intent to re-use those heads? Is a refresh in your plan? Lots of questions left unanswered if you're looking for advice, but you came to the right place!
