Ok I'm trying to figure out what I need to do to fix my trans, here's what happened.
After driving the car normally for 20 minutes, I stop and build some boost against the break, I held the break down harder than usual and got up to about 7psi of boost and probably held it there a little longer than I should have (I was looking at my turbolink). All of a sudden the engine revs up, so I get out of the car to see trans fluid under the car (below the dust cover) and I later determine that it came out of the dip stick. I lost about a 1/2 litre of trans fluid. Car wouldn't drive until I let it sit for 10mins or so. I added more fluid.
Now (a few weeks later) when I put the car in OD the car won't accelerate very much from a stop (I think it's slipping). If I put it into 1 or 2, it will accelerate fine and I can even open up the throttle without many problems. While driving, if I put it in D or OD, it will shift into 3rd, but it won't go into 4th I don't think. At WOT in 1st I get a lot of rattling coming from the trans.
So what happened?!! It was about 90 degrees out, did I overheat my trans? I have a trans cooler.
What is wrong with the trans? Does it require a full rebuild? I just put an Art Carr shift kit in about 3 months ago and it had been working great until now.
Ideas? Thanks a lot!!
Dave
Dave
