I am new to the grand national scene. I just purchased my first grand national and its also my first turbo car. My question is- when do i need to add a computer engine management system? I rebuilt my engine since buying the GN and my list of items under the hood and gauges i already have are below.. i do plan on turning up the boost some time after break in but i am not looking to drag this car. just gonna be a nice street car that does put out. I have a scanmaster on its way in the mail. Some of the stuff on the list does not have to do with my question but i copy and pasted everything and my rebuild list is:
Comp cams
Camshaft 212 lift exhaust and intake 260 duration
Lifters
Pushrods
Double roller timing chain
Valve locks
Valve spring retainers
Water pump
Chromoly piston rings
Speed pro .30 forged pistons
Rods reconditioned turned .10
Crankshaft reconditioned turned .10
Speed pro bearings
Oil pressure switch
Fan switch
Coolant temp sensor
Fel-pro gaskets full set
Fel-pro rear main gaskets
Fel-pro valley pan gasket
Injector o-rings
Rjc power plate
Billet adjustable fuel regulator
Inline fuel pressure gauge
Fuel filter
Fuel pump
Timing cover
High volume oil pump
A/C accumulator
A/C o-rings
Thermostat
Mr gasket radiator gauge cap Knock sensor
Crankshaft sensor
Silicone Intercooler hoses
T-bolt Intercooler clamps
Engine torque strap
Heater core
A/C evaporator core
A/C orifice tube
R12 retrofitted to R134
Optima battery
Starter
Camshaft position sensor
Billet Breather/ oil fill
Throttle position sensor
Idle air control valve
Mass air flow sensor
Alternator
GM battery hold down
Air Charge Sensor
Windshield Washer reservoir
Antifreeze reservoir
INTERIOR:
Triple gauge pillar pod
Double gauge console pod
Autometer ultra lite gauges
Water temperature
Oil pressure
Air/fuel ratio
Voltmeter
Boost/vacuum
Comp cams
Lifters
Pushrods
Valve locks
Water pump
Speed pro bearings
Oil pressure switch
Fan switch
Coolant temp sensor
Injector o-rings
Rjc power plate
Fuel filter
Fuel pump
Timing cover
A/C accumulator
A/C o-rings
Thermostat
Crankshaft sensor
Engine torque strap
Heater core
A/C evaporator core
A/C orifice tube
Optima battery
Starter
Alternator
Air Charge Sensor
INTERIOR:
Water temperature
Oil pressure
Air/fuel ratio
Voltmeter
Boost/vacuum
