I hear a soft knock/rattle that sounds like it is coming from the rear of the engine on the passenger side. I'd say it sounds like a lifter if I had to describe it.
Idle in Park = no knock/rattle
Idle in Drive = no knock/rattle
~1800rpm in Park = no knock/rattle
~1800rpm in Drive while on the road = KNOCK/RATTLE
The sound seems to fade away after about ~2400rpm, but it may just be masked by the engine getting louder in general.
The car idles fine and runs strong... no obvious signs of an engine or tranny problem.
Oil pressure is a solid 50 to 60psi @ 70mph & 20psi at idle with 20w50 Valvoline race oil (the street version).
I cut open my oil filter at last change, and did not see any debris.
All push rods are turning, nothing loose under passenger valve cover.
Both headers have been removed - no cracks found
Things still on the 'to do' list:
Pull driver valve cover and inspect
check flywheel & TCC for loose bolts or other issues
Can anyone offer advice/experience on this type of knock/rattle? please please please don't let this be a rod knock that requires a rebuild.
thanks,
thanks,
