This weekend I will be running my Buick at the track. It's the first time in 4 years and I will be doing it with a basically stock car with a fully restored stock suspension, poly body bushings, and stock turbo. The only mods I have are 42.5lb/hr injectors, 340 fuel pump w/hotwire, Cold air intake, adjustable FPR, 3'' single shot exhaust, ported elbow, gutted cat, Turbo Tweak 91 Octane adjustable chip, and BFG Drag Radials.
First, I plan on adjusting the timing 4.5 degrees like Turbo Tweak states in the instructions using my scanmaster. This should put the timing somewhere around 21-22 degrees. Next, I need to decide whether to run 100 octane unleaded for a mix of about 97 octane, or run 116 leaded for a mix of about 107 octane. Both the 100 and 116 cost the same price. Finally, I figure with 97 octane I should be able to run about 20 psi of boost, and with 107 I could probably push the turbo to 23-24 psi of boost.
What should I expect to run in the 1/4 with the following:
14 psi boost, BFG Drag Radials:
20 psi boost w/ drag radials:
23-24 psi boost w/ drag radials:
Also, would 4-5 gallons of leaded gas for one night at the track be harmful to my engine? I would prefer to run more boost rather than limit myself to 20 psi because of octane issues. The track is only open once a month for the street legal event so I wouldn't be doing this weekly.
