daily driver
- Oct 3, 2005
The last 2 mornings the car was running rough for a couple of minutes and would try to die unless throttled. This morning it went code 34, but ran good after warming up a little . Idles a little rougher though. I had replaced the 3" LT1MAF about 3 weeks ago (new from fullthrottle)when this happened and it seemed to fix it. Now it is back. I am suspecting wiring now although it could be MAF (again?)
I checked and tried to clean all connectione to and from translator-they looked good.
I wiggled all these wires and connectors around while running with no change-still slightly rough idle.
I unplugged the translator while running and the idle smoothed up, plugged it back in and went rough again.
AF does not go below 4 on scanmaster and is usually 4-7.
IAC 34 at idle
TPS .42
Voltage per scanmaster seems higher than normal 13.2 - 14.1 at idle! I have never seen 14.1before.
AF does not seem responsive to throttle:
idle: 4-7
2000 rpm (in the garage): 14-15
3000 rpm (in the garage): maybe 25
WOT (in the garage): maybe 95
I thought it used to go to 255 much easier. Do these numbers with no load at these rpms look OK?
I ordered a new MAF pigtail plug in from Caspers but would like to rewire all 3 wires to MAF but I do not have a diagram. What source is best?
Thanks.
IAC 34 at idle
TPS .42
idle: 4-7
Thanks.
