I did the swap for cheap, here's how. You will be utilizing the factory oil cooler hoses with two extension hoses to an auxiliary engine oil cooler. :biggrin:
All the factory lines will remain in place, unmolested, you are simply building extensions for the factory lines.:biggrin: This variety of radiator has an internal transmission oil cooler. The radiator bolts up perfect but you will have to custom bend some transmission cooler lines to reach the back of the radiator where the trans oil cooler fittings are located (factory radiator has extension tubes going to front of radiator, you won't be using these). Bending trans cooler extension lines will require an inverted flare tool, some bending expertise, and a lot of patience. I can't tell you the amount of times I bent the tubing perfect, double flared the ends, and then realized I forgot to slip the tube nuts on the tubing.
You could take the easy way out and use rubber hose/tubing. I prefer hard lines when possible, no hose clamps, no leaks. Ever.
[autozone]
438162 radiator (1987 monte carlo): $108.99
rubber hose for the remote coolant tank to new radiator (outlet port on new radiator is in a different location): $2-3
5/16" steel inverted flare fuel line, 4 feet (I actually used 5/16" Aluminum tube from smallparts.com-much easier to bend): $8-9
[jegs.com]
130-70273 B&M oil cooler (any cooler will do but make sure it has 1/2" female NPT inlet and outlet fittings, the ID is ~0.84"
BIG): $63.99
771-105 nylon tie mount kit: $5.99
[discounthydraulichose.com]
3384-08 1/2" black push lock hose, 8 feet: $8.80
271-0808 1/2" push lock x 1/2" male pipe swivel (2 fittings thread into auxiliary engine oil cooler): $8.70
292-0812 1/2" push lock x 1/2" inverted flare female (2 fittings attach to the 2 factory engine oil cooler lines): $8.46
3105-05 5/16" Inverted Flare Tube Nut (4 of these for your 2 custom bent trans oil cooler lines): $1.24
Follow basic directions from
F-Body Radiator Installation
Before the install I would suggest filling the remote engine oil cooler with a known quantity of rubbing alcohol in order to know how much engine oil you need to add to the system. After draining the alcohol the remainder will evaporate from the oil cooler if you leave it in the sun for a bit. Mine took an extra 20 ounces. PM me with any questions. You won't believe how much lighter the new system is as the radiator is Aluminum core and plastic sides with the same exact dimensions as the factory unit.
